Antifreeze Question Tap water vs distilled
   / Antifreeze Question Tap water vs distilled #21
Chlorine can corrode aluminum pretty severely but the concentrations in tap water probably aren't high enough to cause any real issues.
   / Antifreeze Question Tap water vs distilled #22
   / Antifreeze Question Tap water vs distilled #23
Ok, so straight antifreeze freezes sooner, got that but what about heat... what is the best solution for cooling in higher temp areas like SoCal ?
Thks for the info guys.
   / Antifreeze Question Tap water vs distilled #24
Scrambler,, to answer your question and in spite of my location,, (I went to school in SoCal) you would want a "water wetter" agent.. This product softens and adds more ductal quality to the water. (It can't form droplets as easy) .. The stuff is popular in the race car world and more recently the motorcycle business..
These products cause the water to lay more flat against the hot spots instead of forming bubbles thus providing more surface area of water touching the hot metal thus cooling better.
(It's also used in a completely different form in your dishwasher.. It's that rinse additive that you add for those shinny dishes..)
The last I bought was 10 years ago and was Redline brand,, and I got it at the auto parts store.. If you buy some, read the bottle and see if it also has a lubricant added.. If it doesn't then always add a pint or so of antifreeze for water pump lube at the least..
DrB
   / Antifreeze Question Tap water vs distilled #25
Id use the distilled water if I could obtain it easy, around me, grocery stores seldom carry it. I do not know of anywhere else to get it.
Up here, the other place you can usually find distilled water is at a pharmacy.
You don't need much scale deposit (meaning, barely visible) to start affecting heat transfer rates. If you live in northern Canada, maybe not a big deal. If you're towing with an overloaded truck in stopNgo Dallas traffic in July.....
I use distilled in all my stuff. Last go with the diesels I went with Delo ELC 50/50, then punched up the concentration a bit with Delo concentrate.
If you are running a high water ratio down south, you might want to dial back the lifespan rating on the coolant bottle (meaning if it says 5 years, change at 3 1/2).
Next level after that is de-ionized water (back to that NASA thing ;) ), as that helps reduce conductivity/corrosion even further.
Rgds, D.
   / Antifreeze Question Tap water vs distilled #26
Local supplies can vary concentration with the season. When we have high runoff (snow melt in Spring, heavy rains other times of the year) some areas boost the chlorine level pretty high - enough that you can notice the smell running the tap, and I don't have a great sense of smell....
Rgds, D.
   / Antifreeze Question Tap water vs distilled #27
Rain water is distilled water.. If you're worried about having some,, put a bucket out back to catch some rain water... After a 24 hour rest period, natures dust will have settled to the bottom.. (Including any other bad organic thing someone might think of) The top half is good to use in your steam iron,, making good whiskey,, also seems to be good for people worried about their radiators..
   / Antifreeze Question Tap water vs distilled #28
most grocery stores, including walmart, and like. you are required to "ASK" for distilled water. they do not shelve it out in the open, but some place in back. i no longer remember why the stores do this though. i just know ya need to ask. generally takes 1 to 2 stores to find a few gallons though. either there out or have a few jugs.
   / Antifreeze Question Tap water vs distilled #29
Around here, Walmart almost always has it on the shelf, right next to the gallon jugs of drinking water. If not there, go the the baby section and look at the label of the "nursery" water -- it is usually distilled water. Auto parts stores will frequently have it, both for filling batteries and mixing in antifreeze.
88 cents per gallon at the Wal-Mart in town.
   / Antifreeze Question Tap water vs distilled #30
I guess you are not a believer in "acid rain"? Distilled water is pretty cheap, and if you care enough to not use tap water, I would just buy it. It's cheap insurance.
Around here, it's on the shelves at Walmart and grocery stores.
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2004 Airburner T-200 (A50121)
2004 Airburner...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
