Anti spin rear axle?
   / Anti spin rear axle? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Just got a used Dodge 3/4 ton last week. The sticker on the inside of the glove box says anti spin axle. I had the back end jacked up on the back the other night, and when I spun the rear wheel on one side, the other side spun the oppisite direction. The test of a anti spin rear end used to be the wheels spun the same direction. Is this test no longer valid for a posi rear end? Maybe the rear end has been swapped out?
   / Anti spin rear axle? #2
What year is the truck and how many miles?
Sometimes the clutches in the differential will wear out after lots of miles, when that happens, the rearend will act like a non-posi rearend.
Or like you said, the axle may have been changed.
   / Anti spin rear axle? #4
Jack up one wheel, if it will drive off the jack it's anti-spin OR put some grease under one wheel (on a smooth surface) & see if the other wheel will drive the truck forward. MikeD74T
   / Anti spin rear axle? #6
The third generation Dodges, with the AAM, do not have clutch packs like the old Dana axles did, instead they have a gear antispin. My 2007 has anti spin and when i jack up the rear end and spin one tire the other spins the opposite direction. A quick burnout will show the antispin though, haha.
   / Anti spin rear axle? #7
I've heard other people mention that if one side is spinning, just touch the breaks a little and the other side will grab. Never tried it with my Dodge, so who knows?
Joe
Yes I tested it out and it is an anti spin. By the way, the 4.10 gears and all that torque make for an awesome burnout.
Good link Kenmac, that answered a lot of my questions on how it works.
   / Anti spin rear axle? #10
Joe
A lot of limited slips need a load to be applied to them to really get them to work. The harder they are loaded the tighter they lock (to a point.) Say you have one side of the truck in the mud and the other on dry ground. Ease the clutch out and the tires in the mud will just spin. Rev it up a little and dump the clutch and you'll probably get both back tires to pull. Applying the parking brake a little can achieve the same effect.
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
UNUSED RAYTREE RMSG29-29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51247)
2012 VOLVO DBL...
