Anti-Scalp Wheel Solution
   / Anti-Scalp Wheel Solution #1
moweraxle
Cortland County in Up State New York
Kubota BX2200
Faced both sides of wheel then drilled and reamed to 3/4" dia. and pressed in oil impregnated bronze bushings then line reamed bushings to the 16mm dia. the OEM size of the axle bolt. 2nd I drilled and tapped axle bolt to except a 1/4-28 thd. grease fitting and cross drilled a hole 1 1/4" from under shoulder of bolt which is between the 2 bronze bushings.
4 pictures, 2 of my used (about 1 1/2 seasons of mowing) wheels and axle bolts and 2 of new wheels and axle bolts up dated to my new standards. Let me know if I can help any TBN members
Picture 2 Old wheel with new bronze bushing installed and axle bolt with grease fitting
Picture 3 New wheel with bronze bushings installed and new axle bolt with grease fitting. Outside view
Picture 4, New wheel with bronze bushings installed and new axle bolt with grease fitting. Inside view
   / Anti-Scalp Wheel Solution #6
I like the solution and I am ready to take my wheels off and ship them to you for the modification. I like your work as shown by my confidence to recommend the mower deck axle wheels after getting mine back in September. I know that you make a quality product and it is always well thought out. Count me in on this one also. Post an address, so I can get my wheels in the mail to you to have them back in time for the mowing season..... thanks /forums/images/graemlins/smile.gif
Tom
60.00 for updating or reconditioning your old one's if in not to bad a shape and free return shipping. Let's make it 55.00 for TBN members and 50.00 for TBN member's who have purchased my mower deck axle set. 110.00 for new wheels w/ bushings and new axle bolts w/ grease fittings off the web site. For any one interested in having their wheels and axles reconditioned. Send to: Mower Deck Axle Co.,LLC
710 Rte. 26
Willet,NY 13863
UPS is the best way.
   / Anti-Scalp Wheel Solution #8
Better make this clear for some of us that are a little slow on the throttle.... We send you the 4 wheels and axles and you will recondition them and return, including shipping for $50.00....That is if we have already purchased the deck axle package.... Thanks
junkman you got it right, send a check for 50.00 with the parts. Please send just the 4 wheels and the 4 axle bolts and keep the lock washer, nut and 1" column at home. Also wash off any dirt. I sould be able to do this in a 2 week max turn around. Thanks
   / Anti-Scalp Wheel Solution #10
If you are doing them in order, then I want to be number 1... LOL..... /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif They are going to be in the mail on Monday... /forums/images/graemlins/grin.gif
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
2013John Deere 244J (A47477)
2013John Deere...
2018 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2018 DRAGON...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
