Oil & Fuel Anti freeze leak when really cold
   / Anti freeze leak when really cold #11
I would change the fuel line, as it may be part of the problem, and can't be too expensive. There are plenty of minor places for a antifreeze leak, so could be minor. CM is right, no tractor should ever leak fluid, no matter the temp.
   / Anti freeze leak when really cold #12
I just noticed on the weekend that my new CK35 HST (with 40 hr's) has leaked a bit of antifreeze on the garage floor. I can't seem to locate the source but I suspect it has to do with the Cab heat. Hopefully just a loose fitting. Mine also started to leak once the weather turned very cold.
   / Anti freeze leak when really cold #13
My bobcat ct335 had the anti-freeze issue....
Put a new hose clamp on the top hose that goes into the the engine.... Stopped the leak, and has not leaked since. Tractor had about 25-40 hrs on it.
Hope this helps.
   / Anti freeze leak when really cold #14
I had the exact same issue with my dk40 except the AC compressor is on top of it. I had the dealer fix it under warranty while it was in for other work and hasn't leaked since.
Jason
1988 KENWORTH T800 DUMP TRUCK (A57192)
1988 KENWORTH T800...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
PORTACOOL (A55745)
PORTACOOL (A55745)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55314)
2023 Kubota M4-061...
