Another work light question
   / Another work light question #1
captjack
Eastern Shore,MD
jd 5400
i put this in the Kubota section but It might be better posted here :
I built a canopy for my L235 and want to add 4 work lights. In the front I am looking at 55w 3X5 with trapezoid beams and in the rear I am adding the 5 inch round flood lights.
My question is - how much can the stock alternator/ generator handle? I do not think I would run all at the same time. The head lights are installed but not hooked up because they are worthless with the FEL installed.
Any thoughts ? Does anyone have pictures of canopy's with lights installed ?
   / Another work light question #2
Check
http://www.tractorbynet.com/forums/customization/139795-led-work-lights.html
and go LED.
   / Another work light question #3
if you find you can't handle four, consider the fact that you are (usually) either going forward or backward ...if you switch them differently you might consider a forward and a rearward on one switch and then the other two switched independently (3 switches) or switch each independently (4 switches) and manage the load yourself. The switches are quite a bit cheaper than installing a larger alternator.
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
2005 Jeep Wrangler 4x4 SUV (A50324)
2005 Jeep Wrangler...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52141)
2023 EAST TEXAS...
2015 Freightliner M2 106 Ambulance (A50323)
2015 Freightliner...
