another vickers pump question
   / another vickers pump question #1
dodge85rc
Bronze Member
MN
trying to find some specs on a hydraulic pump I got. The letters in the casting are hard to read so not sure if these are right.
It is a Vickers pump, looks like a 105-c-12 ? It is a square housing if that matters.
Thanks!
Anybody?
   / another vickers pump question #3
Best I can do, is guess. A V-105 pump would be round, so, I know that can't be it. The only thing I can find that might be close would be V210-5-1C-12-S214. That would be a vane pump. Rated @ 5.4gpm @ 100psi & 1200rpm, and 4.3gpm @ 2000psi & 1200rpm. And a max rpm of 1800. I'm not sure where the model number would be stamped.
I'll try to take a wire wheel to it and try to clean it up and see what numbers are really there. Thank you
Where do you get your specs from?
I have another pump/motor I need to find specs on too.
It is a hydreco 1510c3c1
Anybody know any good websites to find specs on hydraulic equipment?
   / another vickers pump question #7
hydreco is an old name.
I remember mentioning that name back in the '60's
i don't know /can't remember much more
maybe you can find something here for the vickers pump
http://devcocorp.com/american/vickers_vane_v.pdf
maybe post a pix?
google vickers or eaton I bought some seal kits for my V 210 pumps a few years ago and remember finding a link to those pumps.
the identification is
on the rear housing it should be stamped and the model and cartrage installed
2012 Ford F-350 4x4 9FT Knapheide Flatbed Truck (A51691)
2012 Ford F-350...
378812 (A51573)
378812 (A51573)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
