Another Tractor Tragedy
/ Another Tractor Tragedy #1
LOOPHOLE
Horry County,SC
140 Farmall w/belly mower NH 1925 FEL/BH
Saw in paper today, man from Mich killed while operating a post hole auger. 56 years old/ Sometimes I wonder if its carelessness or just bad luck. Maybe they are the same thing.
/ Another Tractor Tragedy #3
PaulChristenson said:
PTOs and Loose clothing...:(
You got that right. When I was a kid there was a barber that lives here that got his glove caught on the PTO where it attaches to the gear box. He is up in years still having neck problems. If someone hadn't been close enough to hear him, he would have been dead. That is why all PTO shafts should have proper safety shields in place. His shields were gone. I know when I worked at a dealership I had more than one customer tell me that when I was repairing their PTO to leave the cover off if it was easier. I never left any off.
/ Another Tractor Tragedy #4
I have a question about the shields on a posthole digger that are above the auger - They are above the AUGER (rotating blade) - Aren't you going to get grabbed by the auger before you get grabbed by the shaft coming out of the gear box???? If you are that close, aren't you a gonner due to the auger???
/ Another Tractor Tragedy #5
RGood...You are right there is no shield on the auger itself...I assumed the shaft that got him was the PTO, but what if he were pushing on the gearbox for whatever reason, the auger connection might caught his sleeve...
/ Another Tractor Tragedy #7
People sometimes have a helper 'guide' the auger, a very dangerous practice. It sounds like the tractor operator may have dismounted and tried it himself, but there really isn't enough information available to say exactly what happened.
However, I will now mount my soapbox and state that in my opinion, a whole lot of deaths and injuries could have been avoided if we had a decent PTO shaft safety shield. The current 'metric' PTO shields are junk, with plastic eyes for the anti spin chains that break if you look at them, and they are a pain in the rear to deal with. People take them off because of their poor design. If the design were better, we would see more people using them, and fewer deaths and injuries.
/soapbox
/ Another Tractor Tragedy #10
No disrespect to the injured man, but the "computer crowd" that makes up TBN is considerably more safety oriented then the redneck crowd of farmers and such I generally run around with.
I was helping in assembling a new PHD on the back of a new tractor, and the guy doing it said, MAN, this is a great PHD (howse) They built this shield so big over the gearbox so I have a firm place to stand on.....................
He was not kidding.
/ Another Tractor Tragedy #11
Getting too comfortable with one's power equipment can result in very unpleasant outcomes :eek: Jay
/ Another Tractor Tragedy #12
I am NOT recommending this... just stating what I had to do the last time I was at my "farm" and needing to dig some holes. I had to do what I did *to be safe*. My L2800's PTO doesn't cut off and dragging the posthole digger over the ground while it was running was tearing things up...
So I found out if I push the clutch in and set the pin to hold the clutch in the "ON" position... and set the parking brake, then I get off the tractor and grasp the PHD auger and spin it back and forth until the cams for the pto disconnected. Needless to say the 15 minute job turned into a couple of hours... unfortunately, it was not all seat time.
Finally, after contacting Kubota... I am to spray WD-40 on the cable?!!?! I'm heading up this wk/ed to see if that will fix the problem... :mad:
/ Another Tractor Tragedy #13
Finally, after contacting Kubota... I am to spray WD-40 on the cable?!!?! I'm heading up this wk/ed to see that that might help :mad:
SHUT THE MOTOR OFF...:eek:
/ Another Tractor Tragedy #14
I'll try that next time... Hopefully the oil will fix the pto problem and that will not be an issue. I'm sure it sounds worse then it really was, I felt totally safe.
/ Another Tractor Tragedy #15
As a Farmedic...I have responded to many farm accidents...and that is one line I have heard more than once from the victims who could talk...:(
Be safe out there...we want to be able to kid you for a long time to come...:D
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
1990 Dorsey 42' Flatbed Trailer (A64912)
1990 Dorsey 42'...
2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
2022 HLA 60in...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
TWO PALLETS OF HOSES AND EXTENSION CORDS/LIGHTS (A67714)
TWO PALLETS OF...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
