John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,049
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I recently added TNT to my NH TC33D. After a few teething pains (thanks for the pointers, Bird) I'm starting to get used to it. I put on the box blade yesterday for the first time (I know, I know... why do you need TNT for brush hogging?!). I've noticed two things that don't seem right:
1) I believe the link is too long. It will only rotate about 2 or 3 degrees forward of level, but rotates back about 17 or 18°. Forward doesn't seem like enough, rear is probably more than I'll ever use. I don't really have a good area to test it out at present, since I can't randomly tear things up until the site for my septic system gets defined. Anyone have a good idea of what a normal working range for of forward/aft rotation on a box blade is? I've only used it a few times with the old manual link, and it seems I was farther forward when using the scarifiers. I have a call in to the dealer who installed it to see what the next size shorter cylinder is.
2) I believe there must be air in the system somewhere. If I rotate the box back a bit, then lower it onto the ground, the top link cylinder compresses 3/4" or so just from the weight of the box on the ground. If I pull forward to put it under a slight load, it compresses even more. (Could any of this be related to the fact that one of the fittings was not even hand tight when I received it? It did not get any heavy use in this condition, but I did move the cylinders around quite a bit before I noticed and tightened it up).
Thanks for any info any of you can provide.
John
John
