Another toothbar question
   / Another toothbar question #1
Molerj
Platinum Member
Eastern Ohio
JD 955, 1978 Economy Power King, JD X500
I found a toothbar for my JD 955 60" bucket at a friends tractor business. It is 66" long,
but I should be able to cut it down & weld it back together to make it fit. He wants 140.00
for it so that would be a pretty good savings for the extra work. On this toothbar the
teeth look to be slipped over a stub & have a driven pin holding them on. Is this how most
of the toothbars are made? Are the ones from Carver made this way or like the ones that
I've seen that were for a skid steer loader that had solid teeth that were welded right on the bar.
Those are considerably heavier & probably too heavy for my tractor. Hope you can understand
what I mean.
   / Another toothbar question #2
Woods sells toothbars made both ways. Their Heavy Duty toothbar has replaceable teeth (and will fit on over a replacable cutting edge), the standard one has welded on teeth.
   / Another toothbar question #3
The toothbar I got has the replaceable teeth. I paid $303. $140 would definitly be worth the extra work.
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A51691)
2016 Kubota SSV75...
PAIR OF SOLIDEAL 15" RUBBER TRACKS (A51248)
PAIR OF SOLIDEAL...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2010 JOHN DEERE 8245R LOT IDENTIFIER 216 (A53084)
2010 JOHN DEERE...
UNUSED INDUSTRIAS AMERICA F08 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
