Another TC29D won't start.
   / Another TC29D won't start. #1
TractorBlues
Western PA
NH tc29d
I have a '05 TC29D that has some of the same starting issues and I have covered most of them and still can't start. It has a new battery w/ cleaned terminals, brand new ignition switch (PN 86405634). Has been blowing Fuse #2 (10amp) for Safety start circuit/ alternator. This is the 3rd ignition switch in 4 years (1 melted) and at least 2 pkg of fuses. I have tried jumping it and still no luck. Any help would be much appreciated. Have seen elsewhere on the site about installing a relay in starter circuit. Is this the answer and is it something I can do or do I have to take it to dealer and shell out a couple hundred? It is a great machine when working, but lately too many issues and I'm afraid there is no permanent fix. Would love to have my starting issue (major headache) solved, permanently.
Thanks,
Chris
   / Another TC29D won't start. #2
Chris...I have a TC 29 D and Jinman and Soundguy have helped me with my starting issues and a stuck clutch and other things...They will see your post or you could PM one of them...they really know...You'll get it fixed...do not despair...;)
   / Another TC29D won't start. #3
TractorBlues, sounds like a intermittent short. The "normal" blown fuse #2 problem just blows the fuse not melt the ignition switch if I recall correctly. Look for chaffing on the wire harness and check for wires going to ground.
I believe I checked all the wires and I think they are good now, but I'll go back and check. The melted switch was from a few years ago and there was some wires chaffed. I corrected the wire issue, at least what I could see, still blowing the fuse, tried following this wire connection and it seems ok. I though I covered all the bases without completely tearing it apart. I'll have to double check.
   / Another TC29D won't start. #5
There are several paths you can take, but your problem points to a faulty solenoid in the starter. It's not getting enough power to fully engage and is staying in the high current draw mode, trying to pull in fully. You might be able to fix your problem with a new starter. There are plenty of sources for a starter for your tractor, all under $100. Here's one example on Amazon. What's happening is that you've probably increased the size of fuse #2 until it is 15 amps or more. With repeated attempts, your ignition switches contacts get hotter and hotter. Finally, the switch burns out because it has a plastic body.
You can change relays, but a better solution might be to see if there are two relays of the same kind in your tractor and swap them. If the problem remains, there's a good chance the relay is not your real problem.
With your starter, it has two terminals that are very easy to get to. Have you ever heard of a remote starter switch? Here is one that I bought from Amazon. With your starter hooked up normally, hook one alligator clip to one lug and the other one to the other lug. Press the button and your starter should engage and start working. What the button does is what's commonly called a hotwire start. It just connects the solenoid of the starter to +12 VDC directly through the switch instead of going through the ignition and any relays. If you try this and your starter does not operate, then you may have bad leads coming from the battery or a bad battery ground connection. Of course, it could also be a faulty starter, but you'd probably hear something in the starter, at least a click.
Since you have a history of starting problems, I think you need to buy a remote starter button/switch and give that a try. You've already replaced too many parts to keep doing what you are doing. Just remember that the remote starter bypasses all safety circuits. If you have the key On, your engine will start when you use this switch. If the key is OFF, the engine will still turn over, but the tractor won't start.
Would the relay conversion work on your tractor? Maybe. . .you can't be sure until you try it. Do you need a new starter? Maybe. . . you will know more if you use the remote switch. All you really know is that your starting circuits are not working and that you are spending a lot of money on parts repeatedly. You have to decide.
Thanks, Jim.
Just purchased remote starter switch and will give it a try when it gets here. You were correct on moving up to 15amps when all 10s were gone and was desperate. Have since bought 2 more packs of 10s. Will also check relays to see if it helps. As for the starter, will try other options first and go from there. Really appreciate the help and links. And will update my progress. Got my fingers crossed.
Thanks again,
Chris
7021 (A50322)
7021 (A50322)
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
Military Axle, Frame, Tires & Rims (A50121)
Military Axle...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
