Another stuck clutch
/ Another stuck clutch #21
As Chris says clutch life depends on use. Loader work usually means more clutching that mowing or harrowing, etc. It also depends on the experience of the user. To put a hard number on clutch life without qualifying these things is meaningless. If you want to qualify all uses one should give a range of numbers 10 hrs to 6000 hrs for example. But to say the average dry clutch lasts 2000 hrs does not provide much useful info, in my opinion.
Opinions are like belly buttons-everybody has one.
Agreed
And the dry clutch on a hydrostat machine is generally only used to start the PTO, so minimal wear and should last many thousands of hours
/ Another stuck clutch #23
Agreed
one would hope it would last, since the hydrostat tranny does the bulk of the load shifting for speed changes..
/ Another stuck clutch #24
Apparently you guys don't comprehend that he wasn't trying to sell me anything, we were at our kids" band concert when we were discussing it and he was trying to help me diagnos my problem without having to split the tractor. He wouldn't gain anything from me buying parts because they would come from New Holland and he works for Deere. Again, folks here don't want to admit they may not see the volume of tractors he does and may not know everything.
/ Another stuck clutch #25
My tractor has about 600 hours on it and about 18 years. Something squeeks when I press down on the clutch pedal. I have also had the disk stick twice. I figure I need to crack the tractor to relube a few places that do not have grease fittings. The input shaft, the pivots on the pressure plate, the places where the clutch linkage goes from outside to inside the bell housing... My diesel car probably needs the same service but I do not hear it squeeking over the noise from the fuel pump.
Keeping with side notes related to clutches, the mechanic who replaced some bearings inside my Toyota's transmission, used a Chinese pilot bearing, or was it a Chinese throwout bearing when he did a clutch job at the same time. Anyhow something started making noise in less than 2 years. I replaced those bearings with Toyota bearings which never made any noise in the years that followed.
/ Another stuck clutch #26
This is an old post and went off the rails quickly! Just an update, finally took it to an independent shop and they split the tractor.
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
Caterpillar 3126 Engine Service and Parts Manual (A63117)
Caterpillar 3126...
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
