Another RTV 1100 Turbo
   / Another RTV 1100 Turbo #1
chuckbuck
Following Mikeyd lead I installed a TD03-7G turbo on my new RTV1100.
After getting everything fabricated and bolted on i fired it up and to my surprise is was not getting any boost. The turbo is brand new and I checked the waste gate to make sure it was not stuck open for some reason.
I have a 2 1/2 inch exhaust so there shouldn't be any back pressure problems.
Any one have any ideas why this turbo is not pumping air????
Thanks,
Chuck
   / Another RTV 1100 Turbo #2
Was the engine under load? A turbo won't build boost at idle. On my F250 Powerstoke I can run at 55 mph steady throttle on flat ground and the boost guage will read 0. If I start up a grade or roll in the throttle the boost will come up. If I step on it hard it will hit 22-25 psi.
Chris
Chris
yes it was under load. I did find a leak in on one of the flanges on the exhaust and now i'm getting 3 psi boost. still too low.
Any one have any ideas why i'm not getting the right boost.
REgards, Chuck
   / Another RTV 1100 Turbo #4
Gotcha,
When I put a boost guage on my truck I got in and revved it up and nothing. I thought, "I know this thing is making boost". Then I took it down the road. Guess it was just me.:rolleyes:
Chris
   / Another RTV 1100 Turbo #5
Check out the last Dyno on the RTV1100, Stock vs Turbo.
Also, The emissions was reduced from 18.2% Peak Opacity down to an amazing 11.2%
You can see it on our site rtvturbo.com
Or Direct:
Kubota RTV1100 Turbo -Vs- Stock - 12-02-10 With Smoothing
Travis Imel
travis@swaginc.com
swaginc.com
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
2018 LEDWELL LW48HT2-10 PB-LP (A52472)
2018 LEDWELL...
WESSEX CHT-100R-E LOT NUMBER 237 (A53084)
WESSEX CHT-100R-E...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
