Another RTV 1100 Turbo
   / Another RTV 1100 Turbo #1
chuckbuck
Following Mikeyd lead I installed a TD03-7G turbo on my new RTV1100.
After getting everything fabricated and bolted on i fired it up and to my surprise is was not getting any boost. The turbo is brand new and I checked the waste gate to make sure it was not stuck open for some reason.
I have a 2 1/2 inch exhaust so there shouldn't be any back pressure problems.
Any one have any ideas why this turbo is not pumping air????
Thanks,
Chuck
   / Another RTV 1100 Turbo #2
Was the engine under load? A turbo won't build boost at idle. On my F250 Powerstoke I can run at 55 mph steady throttle on flat ground and the boost guage will read 0. If I start up a grade or roll in the throttle the boost will come up. If I step on it hard it will hit 22-25 psi.
Chris
Chris
yes it was under load. I did find a leak in on one of the flanges on the exhaust and now i'm getting 3 psi boost. still too low.
Any one have any ideas why i'm not getting the right boost.
REgards, Chuck
   / Another RTV 1100 Turbo #4
Gotcha,
When I put a boost guage on my truck I got in and revved it up and nothing. I thought, "I know this thing is making boost". Then I took it down the road. Guess it was just me.:rolleyes:
Chris
   / Another RTV 1100 Turbo #5
Check out the last Dyno on the RTV1100, Stock vs Turbo.
Also, The emissions was reduced from 18.2% Peak Opacity down to an amazing 11.2%
You can see it on our site rtvturbo.com
Or Direct:
Kubota RTV1100 Turbo -Vs- Stock - 12-02-10 With Smoothing
Travis Imel
travis@swaginc.com
swaginc.com
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
2001 Chevrolet Tahoe SUV (A50324)
2001 Chevrolet...
KUBOTA SVL-75 SKIDSTEER (A52472)
KUBOTA SVL-75...
