Another Rotella question ?
   / Another Rotella question ? #1
GrayBeard
Pa.
First off I'm not real clear on all the API ratings.
I've noticed the Rotella synthetic is API rated for CH 4/SL. (I think)
I've got a 3cyl. Daihatsu diesel that is supposed to use API rated CF or CG oil.
Would the Rotella be a problem ? The engine has about 65 hrs. on it.
Thanks, GrayBeard
   / Another Rotella question ? #2
<font color="blue"> Would the Rotella be a problem ? </font>
No
   / Another Rotella question ? #5
In Pig Latin "ONAY" /forums/images/graemlins/grin.gif. G
Thanks all .
I can feel my "multi-language" skills evolving by the minute !
If its not a "true" synthetic, does it still have the same flow properties a low temps. ?
GrayBeard
   / Another Rotella question ? #7
<font color="blue">If its not a "true" synthetic, does it still have the same flow properties a low temps. ?</font>
Yes, it will. You will never know the difference.(except maybe in the Arctic) It is all a technicality, about how the the end product is arrived at. You will get lower wear, lower fuel consumption and the possibility of extended change intervals with either oils.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
