Another Rotella question ?
   / Another Rotella question ? #1
GrayBeard
Pa.
First off I'm not real clear on all the API ratings.
I've noticed the Rotella synthetic is API rated for CH 4/SL. (I think)
I've got a 3cyl. Daihatsu diesel that is supposed to use API rated CF or CG oil.
Would the Rotella be a problem ? The engine has about 65 hrs. on it.
Thanks, GrayBeard
   / Another Rotella question ? #2
<font color="blue"> Would the Rotella be a problem ? </font>
No
   / Another Rotella question ? #5
In Pig Latin "ONAY" /forums/images/graemlins/grin.gif. G
Thanks all .
I can feel my "multi-language" skills evolving by the minute !
If its not a "true" synthetic, does it still have the same flow properties a low temps. ?
GrayBeard
   / Another Rotella question ? #7
<font color="blue">If its not a "true" synthetic, does it still have the same flow properties a low temps. ?</font>
Yes, it will. You will never know the difference.(except maybe in the Arctic) It is all a technicality, about how the the end product is arrived at. You will get lower wear, lower fuel consumption and the possibility of extended change intervals with either oils.
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
