Another root rake guage wheel thread
/ Another root rake guage wheel thread #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
Here are some gauge wheels that I made this morning to go on my 6' root rake. I went with 10" flat free swivel caster wheels at $27 each. Could have done it cheaper with pneumatic tires, but I hate flats. I ended up with $80 in the pair, but it still beats $300!
Basically just 2" tubing with 1.5" tubing for the adjustable inserts, a few nuts and bolts w/ some scrap flat iron.
/ Another root rake guage wheel thread #2
Very nice! I think you made the right call on the wheels/tires. I went cheap HF and they are always flat. Where did you buy them?
Thanks,
Northern tool.
/ Another root rake guage wheel thread #4
I did the same as lhfarm with the same result though they lasted a couple of years. I replaced the pneumatic tires with solid wood wheels. I cut six 8" circles in 3/4" exterior plywood scraps on the bandsaw then glued and screwed three circles together to make two 2 1/4" wide wheels. When glue dried I bored for the 5/8" axles at the radius point for the circles on the drill press. No flats no mo.
I've run these two years now with no problems except that the outer edge plies have chipped a bit. The wheels tend to cake up with clay when conditions are damp but I'm going to mount scraper bars on the wheels ant that should keep them clean.
227 (A64278)
227 (A64278)
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
