Another road thread.. 25 degree sugar sand hill, how to make a tractor path?
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path?
Crushed concrete is available locally. Maybe that over road fabric?
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #12
You could check on crushed limestone, too, but I don't think it locks together as well as crushed slag or cement.
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #14
Crushed concrete will deteriorate if exposed to the weather.
Slag would be good choice if available at reasonable cost
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #15
Neoweb or something like this might work. The issues is whether it will slide on the sand underneath, given you are putting it on a hill then driving on it.
You might be able to do a strip wide enough for a tractor without adding much of anything else.
PRS-Neoweb(R) geocell cellular confinement systems
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #16
Two rows of planks.
Thanks for all of the ideas. Two rows of planks or geotextile each look good to me. With anything like planks, I need to figure out how to make them rough enough to get good traction going up that 25 degree Hill.
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #18
Can you cut a path that lessens the slope of the hill at all? It would greatly decrease the flotation and shear resistance needs of your road. Geo textile or geogrid would be my suggestion to give the rock some base to keep from pushing through.
No-can-do on making the path track across the hill the 20 and 25 degree area is the gentle part. For planks I'm thinking along the lines of pole barn center match. I'm still concerned about traction with that idea though.
   / Another road thread.. 25 degree sugar sand hill, how to make a tractor path? #20
What tires are on the tractor?
1996 Ingersoll-Rand VR642C (A47477)
1996...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2005 Bomag BW266 Double Drum Roller (A54865)
2005 Bomag BW266...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
