Mowing another rck60-24b mower question
/ another rck60-24b mower question #1
tony3542
Nashville Tn
2006 B7610hst
I bought a used B-7610 with mmm rck60-24b .I've never been able to get the side to side adjusted correctly.If I understand the manual you should turn the connecting rods to do this adjustment?I wanted to check here before I started turning things.Right now the left side is about 3/4 of a inch lower than the right side.The manual is confusing to me,sorry.Thanks for any help.
tony
/ another rck60-24b mower question #2
You got it. Thhe rods that connect the lift arms to the deck are threaded. You will have to screw one up or the other down in order to level it side to side. Just make sure that you adjust it so that the front is still slighylt lower than the front (approx 1/8 to 1/4 inch). Good luck.
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2023 Dodge Ram (A66408)
2023 Dodge Ram...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
