Mowing another rck60-24b mower question
   / another rck60-24b mower question #1
tony3542
Bronze Member
Nashville Tn
2006 B7610hst
I bought a used B-7610 with mmm rck60-24b .I've never been able to get the side to side adjusted correctly.If I understand the manual you should turn the connecting rods to do this adjustment?I wanted to check here before I started turning things.Right now the left side is about 3/4 of a inch lower than the right side.The manual is confusing to me,sorry.Thanks for any help.
tony
   / another rck60-24b mower question #2
You got it. Thhe rods that connect the lift arms to the deck are threaded. You will have to screw one up or the other down in order to level it side to side. Just make sure that you adjust it so that the front is still slighylt lower than the front (approx 1/8 to 1/4 inch). Good luck.
THANKS>>>
KUBOTA L2650 TRACTOR (A51243)
KUBOTA L2650...
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
2016 FORD F-150 XL SINGLE CAB TRUCK (A51243)
2016 FORD F-150 XL...
Toro Z Master 2000 Zero Turn Mower (A50322)
Toro Z Master 2000...
Loader Arm (A51691)
Loader Arm (A51691)
BUSH HOG 35-06 - 6' REAR MOUNTED BLADE SCRAPER (A51243)
BUSH HOG 35-06 -...
