Another PTO Generator question
   / Another PTO Generator question #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
I posted a question about PTO Generators here a while back. While doing some more research I have been hearing that it is not recommended to run a PTO Genny with a 2 cylinder tractor because the engine does not run smooth enough.
I have a YM 2000 and I don't want to spend $1,500+ on something that will not work with my available equipment.
Any Ideas on this theory? has anyone ran a pto genny with a 2 cyl. tractor successfully? thanks.
   / Another PTO Generator question #2
I'm not sure where you heard that drivel.. but is sounds like a real bucket load to me. Ever seen a gas engine on a portable generator? ever count the number of cylinders? maybe 2 on an expensive unit.. 1 on many o fthe units 12.5hp and down..
Your pto is constantly spinning.. the tractor governor needs to be able to manage the load. A 1500$ pto gen sounds like a 10-15kw unit. The only issue is load capacity. In general, you want about 2ptohp per kw.. this number has some fat in it.. but it's a good rule of thumb. I'd guess a 2000 is gonna max out just under 10kw Still.. I'd rather own a 12kw genny and run it at 10kw, than own an 8,5kw and run it at max all the time.
Soundguy
   / Another PTO Generator question #3
Chris and I are on the same page on this one, your tractor will be fine.
   / Another PTO Generator question #4
While there is some truth to what you heard, from a practicle standpoint there should be no issue.
The seed of truth is from a absolutest standpoint. With only one power pulse per revolution and depending upon what kind of rotating mass there is, if the generator's output was put on a scope you would likely see something other than a PERFECT sine wave. This is due to small variation in shaft volocity at any given point during a revolution.
AS for spenting $1500 for a genset, I've give serious thought on getting one of the stationary genset from China that are designed for 27/7 operation for yrs on end. They are very heavy, large rotating mass which helps with maintaining constant speed. Nothing but a set of brushes and ind std bearnings to wear out.
10kw gen should coast about $500 and a maybe a couple hundred more to make a mount and 3pt drive.
Might want to check here for some good info on these generators http://utterpower.com/ST.htm
   / Another PTO Generator question #5
I would like to know where I can buy a 10kw pto driven generator looking for new thanks for the help
   / Another PTO Generator question #6
Anyone know what the fuel consumption would be on a lets say 50% load . Ive been kicking the idea around myself .
   / Another PTO Generator question #7
Why do you guys want PTO generators? They are roughly the same price as a self powered genset, and will put a ton of hours on your expensive tractor.
   / Another PTO Generator question #8
Norm , I was considering one because the portable ones are mostly junk unless you spend a few grand . Plus there really noisy,Consume allot of fuel and my tractor will run on more types of fuel if need be like Bio home brew. Expensive ? I gave 1200 for my tractor and tiller. Hours mean little if there taken care they will last forever.
I have a 5.5 kw portable generator now and I agree with FlashPiont, They are absolute JUNK. It never runs right and I have had it rebuilt twice, Besides i want more power and my wife can fire up the tractor much easier than handling the crappy portable unit. I also have 76 acres with a bunch of treestands around it and ponds with food plots around them and I want to be able to easily take a generator to the stands to fix them or the pump to the ponds to water , just general portability.
I don't forsee a ton of hours put on my tractor barring a major power outage, Besides I bought my tractor to use. If I put hours on it then so be it.
Soundguy,
Thanks for clearing that up for me. I have read a ton of posts on here about PTO gensets and I knew you would have the answer. /forums/images/graemlins/grin.gif DO you think a 10kw would run my well pump, a small taco boiler pump and a 220V air handler ( I have a coal boiler with forced air) and the T.V. I need that or my 2 and 3 yr old would drive my wife nuts !!!
   / Another PTO Generator question #10
</font><font color="blue" class="small">( Why do you guys want PTO generators? They are roughly the same price as a self powered genset )</font>
Perhaps on the units under 8kw.. but ont he larger units.. like the 12.5kw I have.. there is no price comparison. I paid 999$ for my 12.5kw unit... comperable unit at a box store was 1500 for a cheapy import, and close to 2000 for something I can rebuild the brigs carb on every year just so I can get it to start... Just one more engine to maintain. besides... I'm quite sure my tractor engine will last a whole lot longer than a maxed out one lung gas job...
Soundguy
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2009 Kubota RTV1140 (A50123)
2009 Kubota...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
