Another Predator Engine Swap
/ Another Predator Engine Swap #21
Bumping this up as I've seen some chatter on TBN about log splitters and Harbor Freight engines. Mine's still working great, by the way. :thumbsup:
I did this one recently. Changed out a 11 h.p. Briggs to a 16 h.p. DuroMax electric start.
/ Another Predator Engine Swap #22
Question .....
I had planned on swapping the engine of a chipper shredder a few years back. I got the thing in the early 90s and it has a 5HP Briggs on it that died. Problem was the HF engines had a smaller shaft than the Briggs (3/4" vs 1" if I remember right), so I would have needed an adapter. I found a few for cheap, but the sellers couldn't assure me they would take the stresses of a chipper/shredder, so I never did it. Do any of their newer horizontal shaft engines have a 1" shaft?
/ Another Predator Engine Swap #23
Has anyone had any experience with vertical shaft Predator engines? My local small engine guy agrees the horizontal shaft ones are good, but the vertical shaft ones are junk.
I've got an older Greyhound on a mower. Tempermental getting started at times, but once running it does fine. I can hear it bog and adjust itself back up to speed if I get into taller grass.
/ Another Predator Engine Swap #24
Question .....
I wouldn't be afraid of any 3/4" or 1" .
Check these guys out:-- Gas Engines - DuroMax - Brand.
That's where I bought mine mentioned above. $299 delivered w/ electric start. They should have the size you're looking for.
/ Another Predator Engine Swap #25
It's not the shaft size on the engine. It's the adapter between the HF engine and the shredder I'm wondering about. If the new HF engines have a 1" shaft, I won't need any adapter.
You'd have to look at the specs on each individual Predator engine. The 6.5hp one I have was 3/4" shaft, and so was the BS engine it replaced. So, it was a direct bolt-in replacement with no adaptors, drilling, etc...
I think I saw their 13hp engine had a 1" shaft.
It's easy enough to look up. Go to Harbor Freight. Select an engine. Go to the tab that offered links to the manuals for the engine and it'll list the shaft size for that engine.
/ Another Predator Engine Swap #28
On fuel/carburetor issues, with crummy fuel we have now a days, I usually shut off gas at tank (or empty tank) and run engine till its out of fuel (carb bowl)... Seems to save the crud/corrosion from building up in carb and causing problems...
Recently picked up a used Honda WX15 water pump for $40... Would not run, removed carb cleaned all the jets and passages caused by crummy fuel, runs like a champ now
.... Saved $460 over cost of new one...
I know discussion was on Predator engines, but even at the very low price, this simple step may save you some headaches....
Dale
/ Another Predator Engine Swap #29
/ Another Predator Engine Swap #30
Yeah, I pulled a third time before I remembered to turn it on!
I recently bought a Snapon rolling tool chest from someone. To sweeten the deal (or get rid of his trash?) he threw in an air compressor, generator and a plethora of tools.
Looked at the air compressor and it has the predator engine on it.
He later explained that it had an electric motor which burned out so he replaced it with a gas engine.
I probably pulled on that SOB for 20 minutes, fearing the entire time the (vertical) air compressor (with twin cylinders) would topple over....
Then.... I realized I was being a dufas.... I looked around a bit (I had already turned the switch on) BUT.... in my haste to show my stupidity.... I neglected to turn the fuel petcock on...
Now that I know to turn the fuel on (duh!), it's a 2-3 pull starter.
/ Another Predator Engine Swap #31
How is it driven?
If the motor runs a pulley, just get another pulley of the correct size with a 3/4" bore.
If it goes through a connector such as a Lovejoy, you should be able to get the engine side with a 3/4” bore.
Aaron Z
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
UNUSED WOLVERINE HYD CONCRETE CHUTER (A64281)
UNUSED WOLVERINE...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
