Another pipe-on-the-FEL for pushing snow
   / Another pipe-on-the-FEL for pushing snow #41
Thanks JB4310, ksimolo, J_J, ray66v and Iron Horse for the warning about galvanized fumes/smoke!;)
It might be a good idea to wear a respirator when welding on galvanized.- If one would fit under a welding helmet.
Paul.:)
   / Another pipe-on-the-FEL for pushing snow #42
i usuall run a fan right there. no matter what im welding . Get the fumes away as soon as I can...
   / Another pipe-on-the-FEL for pushing snow #43
Or buy a used adflo helmet - keep you cool and out of the fumes.
Ken
   / Another pipe-on-the-FEL for pushing snow #44
A budget alternative for part time welders, who find a respirator creates as many problems, as solutions, is to use a cheap OIL-LESS air compressor, like from Sears, and locate it in a place where you are assured it has fresh air to pump.
Route a clean air hose from that compressor, to a regulator that will allow a low, but steady flow of air inside the helmet.
When the valve is set correctly, the positive pressure inside the helmet will keep the smoke and fumes out.
Do not use shop air, or air that comes from a oil lubricated compressor, or old hoses, and regulators that have been used on oil lubricated systems.
This is not going to be OSHA approved, but it will always be better than breathing the toxic fumes.
   / Another pipe-on-the-FEL for pushing snow #45
Ill be I never seen or heard of these.Reasonably priced they are..
Deprecated Browser Error
I dont know where people are welding. inside with no ventilation? What am i missing here?
   / Another pipe-on-the-FEL for pushing snow #47
Being in the natural gas distribution business, I would think that a piece of 1-1/4. or 2" plastic gas line would be perfect! You'd want to get a scrap piece of 'stick' rather than coil, which retains it's coil 'memory'. We cut it with an electric chain saw, before facing it for butt-fusion. I'd bet that a long cut with a chainsaw, would leave a perfect 'kerf', to slide over the bucket blade. This plastic is much softer than PCV, thus, wear may be an issue, but I doubt it would 'shatter'! Talk to your local utility worker. They're pretty good folks! ~Scotty
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2003 FORD F350 XLT SUPER DUTY CREW CAB TRUCK (A57192)
2003 FORD F350 XLT...
UNUSED FUTURE CAT 301 EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE CAT...
UNUSED 1RANCH 1RIG-13' 14' BI-PARTING IRON GATE (A57193)
UNUSED 1RANCH...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
Amadas SPC-4 (A53317)
