another newbe question---25hp Farm-Pro
   / another newbe question---25hp Farm-Pro #1
frigman
oxford ohio
farm pro 2425
do I check the fluids level with the dipstick screwed in or out.
Also the center extrusion under the hydraulic valve assembly is leaking out the weep hole---are there "O" rings to be replaced or is it metal to metal seal?---Last question---The rear wheel lock shift handle won,t stay down--it pops up immediately ? All of your help is much appricated.
   / another newbe question---25hp Farm-Pro #2
The dipstick thing is an ongoing debate. the trans and hyd level arnt that touchy. I wouls screw in the engine as we push in the old type when checking. the diff lock is supposed to be held in momentarily while you are getting unstuck and springs back when the pressure is equalized in the differential. Not sure I understand the leak, is it a few drips (hense the need for a weep hole or a constant leak?
   / another newbe question---25hp Farm-Pro #3
Most of the instruction manuals that come with any Asian equipment I've owned specify threaded dipsticks check levels with the threads resting ON the hole and unthreaded dipsticks check levels by being pushed in as far as they'll go. Neither the Jinma nor the KAMA owner's manual specifies, so I just go with what is specified for the other Asian stuff.
Weep hole? Which hydraulic valve assembly?
The lever is designed to be held in place while diff lock is engaged. When you get unstuck, just let go.
//greg//
Unused 2025 SDLANCH SDLL30 Mini Track Loader Skid Steer (A51691)
Unused 2025...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
