another light question for a CK20HST
   / another light question for a CK20HST #1
edkinct
NE Connecticut
CK20S HST
First thanks for your patience, this is going to be my thanksgiving day project, if I don't fall asleep on the couch after eating :)
1-what is the size of the rops (xx"-xx") I need to buy a bracket after work and forgot to measure it this morning.
2-I am going to wire it off the customer fuse in the panel, is this alright? I assume its there for this reason and should have nothing currently coming off of it. I am wiring them to an on-off-on rocker switch, there will be one light facing forward and one facing the rear.
3-where is the best place to run ground wire from the work lights? I looked at the rear of the tractor and all the nuts seem to be welded in place on the fenders etc.. should I run it to one of the nuts farther down on the frame?
Thanks in advance
I will take pics and let you know how it goes.
   / another light question for a CK20HST #2
Hi,
There should be a pair of bullet connectors in the right rear of the tractor coming out of the harness above your fuel filter area(Red wire and Black wire). This is a hot and ground pair which the (optional)factory work light plugs into. I never bothered to check if it is keyed power or switched power, just know it is 12v+ and ground. This is an easy place to tap for light power.
KiotiDave
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2022 BOBCAT T740 SKID STEER (A52709)
2022 BOBCAT T740...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2016 Chevy Traverse SUV (A56859)
2016 Chevy...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
