another light question for a CK20HST
   / another light question for a CK20HST #1
edkinct
NE Connecticut
CK20S HST
First thanks for your patience, this is going to be my thanksgiving day project, if I don't fall asleep on the couch after eating :)
1-what is the size of the rops (xx"-xx") I need to buy a bracket after work and forgot to measure it this morning.
2-I am going to wire it off the customer fuse in the panel, is this alright? I assume its there for this reason and should have nothing currently coming off of it. I am wiring them to an on-off-on rocker switch, there will be one light facing forward and one facing the rear.
3-where is the best place to run ground wire from the work lights? I looked at the rear of the tractor and all the nuts seem to be welded in place on the fenders etc.. should I run it to one of the nuts farther down on the frame?
Thanks in advance
I will take pics and let you know how it goes.
   / another light question for a CK20HST #2
Hi,
There should be a pair of bullet connectors in the right rear of the tractor coming out of the harness above your fuel filter area(Red wire and Black wire). This is a hot and ground pair which the (optional)factory work light plugs into. I never bothered to check if it is keyed power or switched power, just know it is 12v+ and ground. This is an easy place to tap for light power.
KiotiDave
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Montreal ST225/75R15 Trailer Tires (A50322)
Montreal...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
