Another homemade toothbar
   / Another homemade toothbar #1
JohnF_ASI
QLD, Australia
Kubota L1501DT
Here's my version of a relatively simple toothbar for my 1200mm (4 foot) bucket.
I started by getting the main support and side bars in place so I could measure the total thickness for the teeth..
That allowed me to start cutting the teeth from 25mm (1") solid bar.
I did this with only 2 cuts using a drop saw - 1 at 45 degrees and 1 at 22.5 degrees (which gives the 45 degree slope when they're turned around)..
Then into 'production mode'..
Oops! Clicking too fast before attaching pic..
Welded and painted..
Closer view..
Slipped a couple of lengths of 30mm x 2mm SHS onto the 2 outside teeth and gave it a test..
Front view.. Couldn't have done this before.
Now I plan to make a set of 4 square tubes to slip onto the inside teeth so it can also be used as brush forks..
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
Unused Delta Crash...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
1996 International Bucket Truck (A50323)
1996 International...
