another finish mower question
   / another finish mower question #11
Also, what does the roller do for you? bw
   / another finish mower question #12
The only way to really find out how much abuse anything will take is to go just beyond that level and break something. THEN you know where the line is... just behind you. /forums/images/graemlins/crazy.gif
If you're planning on mowing something like you described I'm not sure a finish mower is what you need. That's why there are rotary cutters out there. A finish mower is for mowing lawn-like areas, not areas with bricks, 3" branches, etc.
As to rollers, they are to help you eliminate scalping your lawn when the middle area of your mower would go over a slightly raised area.
Good luck with whatever you decide to do. I hope this helps. /forums/images/graemlins/smile.gif
i am going to the dealer to have them look at the poor cut on the right side (see other post subject) and i will have them remove the chain and will report back as to the results. thanks to all for the input.
don
   / another finish mower question #14
I don't run over these limbs on purpose.But mowing trails through the woods ( in a couple weeks ) the grass and weeds get pretty tall. Limbs fall out of pine and poplar trees all the time .Its hard to see all of them and on occasion you hit one.I use a Woods 6' BH about once a month or less.But now and then you can still hit a rock thats worked its way up. I have never had a finish mower and have been mowing for about 38yrs.I was just wondering ----------if I bought a RFM ----- would hitting " something" once in awhile do alot of damage. /forums/images/graemlins/confused.gif
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
UNUSED FUTURE 15" MINI GRAPPLE (A57193)
UNUSED FUTURE 15"...
