Another FEL not liking the cold
   / Another FEL not liking the cold #1
johns_dmax
Mustang OK
NH Boomer 55, Bobcat Toolcat 5610
I have a JD 5105 with 522 loaded that is acting up.
The curl circuit has been a little stiff with the colder weather but with our blizzard and temps down in the single digits it just won't respond. When I try to curl the bucket the stick won't move. It'll dump just fine. I assume its the cable that connects the control to the valve but haven't been able to get out there and take it apart. I have water lines in the house and a well that's frozen so those get priority. Any one have any ideas?
   / Another FEL not liking the cold #2
In the colder climates we are use to things freezing up. Some of the quick and fast penetrating lubes should work. WD 40 is quick and nasty but it does not last. Then you can chase that with oil, spray on lube with a carrier ,thin spray grease with a carrier.
Craig Clayton
Thanks, I'll give that a try tonight. I'll let you know how things work out.
Thanks Craig. That did trick. I guess I need to add lubing the cables to my maintanence schedule.
   / Another FEL not liking the cold #5
Use Fluid Film, it will last MUCH longer than any other lubricant will.
Thanks KennyD. I used a penentrant/lube spray I had on hand. Once it warms up a bit I'll clean both cables and give it a try.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2007 Ford Escape XLT SUV (A51694)
2007 Ford Escape...
International 574D Tractor (A53117)
International 574D...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
