Another DIY Grapple
/ Another DIY Grapple #11
You may want to weld some mesh to the back of the grapple to protect your tractor when ramming into brush
Thanks for the thought Murph, I already have the mesh sitting in the shop... I am a bit curious about branches, sticks, etc. getting caught in the mesh and tearing it up but I guess that's better then them making it to the radiator.
/ Another DIY Grapple #13
Looks awesome! How much would you say was
Tied up in materials?
/ Another DIY Grapple #15
How wide is it? Did you get the logo cut with Plasma or water jet?
/ Another DIY Grapple #16
Sorry I guess I should read before posting. your first thread said it all........................Nice work.
I'd say about $425 including the cylinder and the cutting of the logo.
/ Another DIY Grapple #18
I just bought material to start my grapple for my bucket and your hinge pin for your grapple is a great idea! I'm going to change my design to be like that, if you don't mind me asking what size is your pin that u used to go threw the base of the top grapple hinge?
Thanks
Thanks
If you are asking about the pivot for the grapple portion, it's a 3/4" bolt. The "hinge tube" that spans the width of the grapple is 2" diameter 3/16" wall tubing with a 1" long plug turned on the lathe and welded into the ends of the tubing. I tapped the plug and the grapple arm and then put a set screw into the plug to keep the bolt from backing out. The bolt passes through a piece of 1/4" wall DOM with a grease zerk in it for the pivot bracket on the frame. Hope my explanation makes sense.
/ Another DIY Grapple #20
Yes it does thanks.
I bought a tube that's appox 2" x 1/4 wall and a shaft that runs threw it snug. So I going to use the whole length like you instead if making individual hinges for both sides. Simpler and effective. Thanks. Gonna start this weakend and ill try to post some pics of progress.
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
Deere 331G (A53317)
Deere 331G (A53317)
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
