Another Corn Question
/ Another Corn Question #1
yak651
North East Wisconsin
Case 530 (old!!)
Ok, if i'm going to plant two different varieties of super sweet corn and indian corn what is the rule of thumb to prevent cross polination? I believe I've read that if they tossel 15 days apart you are ok. So my question if one corn is 75 day and the other is 80 day, will i be ok if i plant the second one ten days after the first one? I probably should've just brought one seed and just staggered the plantings to get the corn at different dates, now I'll know better for next time.
/ Another Corn Question #2
I would wait 15 days to plant it... I'm not sure how much you can actually trust the "80 days to maturity"... it all depends on the weather/temperature starting from the time you planted the first patch of corn...
I've got the same problem as you... 2 varieties to plant. My first patch, Illini Extra Sweet, just popped out of the ground, then the weather turned very cool and rainy... and it has just sat there, I don't think it's grown an inch since it's come up nearly 2 weeks ago... and now it's kinda getting down to the wire to get corn in the ground, so hopefully if we ever dry out enough to get the Peaches-n-Cream in the ground, there will be enough growing days between the 2 so that they won't cross-pollenate...
2022 Belshe WB14 18ft  12000lb Trailer (A64047)
2022 Belshe WB14...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
Arrow Quip 10' Corral Panel X 5 (A64047)
Arrow Quip 10'...
EZ Trail 3400 (A63118)
Ruff and Tuff Crew Electric Golf Cart (A62183)
Ruff and Tuff Crew...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
