Another Corn Question
/ Another Corn Question #1
yak651
North East Wisconsin
Case 530 (old!!)
Ok, if i'm going to plant two different varieties of super sweet corn and indian corn what is the rule of thumb to prevent cross polination? I believe I've read that if they tossel 15 days apart you are ok. So my question if one corn is 75 day and the other is 80 day, will i be ok if i plant the second one ten days after the first one? I probably should've just brought one seed and just staggered the plantings to get the corn at different dates, now I'll know better for next time.
/ Another Corn Question #2
I would wait 15 days to plant it... I'm not sure how much you can actually trust the "80 days to maturity"... it all depends on the weather/temperature starting from the time you planted the first patch of corn...
I've got the same problem as you... 2 varieties to plant. My first patch, Illini Extra Sweet, just popped out of the ground, then the weather turned very cool and rainy... and it has just sat there, I don't think it's grown an inch since it's come up nearly 2 weeks ago... and now it's kinda getting down to the wire to get corn in the ground, so hopefully if we ever dry out enough to get the Peaches-n-Cream in the ground, there will be enough growing days between the 2 so that they won't cross-pollenate...
(NEW) 12 BLADE GROUND BOG HARROW (A63290)
(NEW) 12 BLADE...
2018 Broce BW260 (A62180)
2018 Broce BW260...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Toro Trailer W/Kohler CH740 Engine (A62183)
Toro Trailer...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
