texbaylea
Veteran Member
- Joined
- Feb 6, 2004
- Messages
- 1,923
- Location
- Brazos County Texas 77808
- Tractor
- Kubota L3130HST w/LA723 loader
gotrocks -If the "back" option is grayed out on the right click menu it means that there is no page further back to go to. Everything is working as it should. You have reached the page that started your viewing session.
weldingisfun - It sounds like there are several programs running in the background that are using up the available RAM memory. All the special little programs like special toolbars, sidebars etc. take up memory.
There are some free programs I use to help keep my computers running as they should. They are Wise Disk Cleaner, Wise Registry Cleaner, and CPU-Z. The windows task manager will also show you which processes are using large amounts of memory. Another freebie is CCleaner. Don't use some on-line "cleaner" as you can't be sure that it won't add more stuff to your computer than it clears out.
When using Task Manager I have entered the process name in Google to get specific informatio about what it is so I know whether it can be stopped or not.
Another thing - if you use the tab function on your browser a lot that takes a lot of memory.
Hope this helps
Vernon
Hope this helps
Vernon
