Snow Another BX snow plow question
   / Another BX snow plow question #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
Has anyone installed a Warn ATV snow plow on a BX loader? A 6' plow and frame are only about $300 which doesn't seem bad.
   / Another BX snow plow question #2
I seriously considered this. It will work fine after you arrange a lift and tilt system. IF you only use it on smooth surfaces with no frozen in objects. The warn plow I looked at will probably bend up if you catch a curb, root,etc. A 4x4 quad is around 650# a bx2350 around 1200# with considerably more torque and momentum. If you do this please post some pics and tell us how it does.
I just installed the kubota plow and it is really heavy duty and nice.
I'd be mounting it to a BX2200 loader bucket. As you can see this Warn plow has springs to hopefully avoid any bending. I have a similar setup for my Cub Cadet loader. The bar going up from the plow frame contacts the top of the bucket when I tilt the bucket. This gives me a little down force on the blade when needed.
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
Compressor (A55973)
Compressor (A55973)
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
