Another brush cutter ?
   / Another brush cutter ? #1
Bever22
If I got a 5' brush cutter for my 2310 and overlap the rows would it work ok? I like to cut my fields on a regualr basis with a brush cutter but would like one a little bigger so I can overlap the rows to get rid of the uncut streaks left behind.
   / Another brush cutter ? #2
A 5ft cutter is too big. You will have stablitiy problems when trying to lift the cutter and the inertia required to start and stop the load of the 5' blades is probably more than the tractor is designed for. Suggest you use a 4' cutter.
   / Another brush cutter ? #3
Yes 4ft or even a 42" if cutting heavier stuff.
48" it is, thanks for the help.
I purchased the 4' today, thanks for the info.
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
1997 JLG 40 Electric 40ft Articulating Boom Lift (A50322)
1997 JLG 40...
