Another backhoe thumb
/ Another backhoe thumb #1
Corm
Fairfax, Franklin County, Vermont
1999 Cub Cadet 7260, 1953 Farmall Super A
Hi folks. I have a Cub Cadet 7260 with a C.C. 418 backhoe (7.5 foot digging depth). I've been wanting a thumb since I bought the hoe. Recently I bought some plans for one, and built one based loosely on the plans. This first picture (if I've attached a picture correctly) shows how I started making the 2 jaws`for it. It is 2 pieces of 3/8" x 4" tacked together, with a series of 1/2" holes drilled between them. This pitcure shows it set up on my milling machine table being drilled.
This next picture shows the jaw pieces taken apart, the ends cut and welded to give me the 'jaws'
This next picture show the frame of the thumb welded up. I ended up having to change this slightly to size it for my hoe, but essentially it is the same
...I had to try it out before painting it
These last two pictures show it with a fresh coat of paint
/ Another backhoe thumb #7
Nothing wrong with that.
Please show us a pic of the thumb folded too.
That's a real Bridgeport in the photo, you are lucky.
All the best,
Martin
Oops, one last one showing it in the transport position. This was a fun project. Total cost of steel was $65.00, and $10.50 for a can of spray paint. The three pins I turned down myself from an old vice leadscrew that I had.
Corm
/ Another backhoe thumb #9
Wow, that's service. Thanks for the folded pic.
I'm gonna maybe get beat up a bit here but that thumb is right up my alley. I looked at the hydraulic thumb projects and don't get me wrong, thay are right slick and all, but I do think the manual model is more practical for me. A lot less involved and it gets the job done.
Nice job.
All the best,
Martin
/ Another backhoe thumb #10
Looks like a nice thumb.
I recognize the Woods 7500 backhoe. Note how thin the
dipper stick steel is (about 1/8"). Be careful that you
do not distort it when the bucket pinches hard against the
thumb....
The greatest danger is at the end of the dipper stick.
AntrimMan - I looked long and hard at making a hydraulic thumb. In the end I couldn't justify the considerable extra $$ for the limited use I'll give it here at home. If you think you want to do something similar, I can tell you where I bought the plans, and the modifications I made to them to fit my hoe.
Corm
dfkrug - Thanks for the words of caution. I have a friend that has a 3 pt mounted Woods 7500. He had a thumb put on it a couple of years ago, and hasn't had a problem after more use than I'll probably ever give mine.
Corm
/ Another backhoe thumb #13
Very nice of you to offer. This kindness is what makes TBN such a pleasant experience.
There must be some chinese in me somewhere. All I need is the picture to knock off the thumb, (no offense to our asian friends).
Thanks for the offer,
Martin
/ Another backhoe thumb #14
Very nice, and very impressive. Thank you for sharing. As with other "really cool" projects, I plan to file your pictures away so if I ever want to build one I will have some ideas. Thanks.
