Another approach to power chute rotation for snowblowers
   / Another approach to power chute rotation for snowblowers #1
PHPaul
Platinum Member
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I started with an old 12V boat winch I scrounged out of a dumpster. The original design used a wire rope drive with several wraps around the winch drum and connected to the chute in the same manner as the original manual crank. In practice, it didn't work all that well as I couldn't figure a way to keep enough tension on the wire rope to keep it from snarling back on itself and jamming on the winch drum. I built a winch mounting bracket that bolted to existing fixtures on the blower.
Plan "B" was to convert it to chain drive. This involved removing the winch drum, fabbing up a new axle to go in it's place and putting a #40 sprocket on it.
I also cleaned up the chain path by replacing the hex head bolts on the chute locator clips with carriage bolts, put a PVC chain guide on to keep the chain from snagging on the chute mount, and built a little tensioner to keep the chain from jumping the sprockets.
The whole thing is controlled from a DPDT Momentary toggle on a bracket on the ROPS, right where it's handy as I'm looking over my shoulder while blowing. The curly cord is my warning flasher.
As you can see, the chain clips to the original tab that the manual cable-and-crank system attached to, just used a master link on each end of the chain and through the holes on the tab. So, I haven't done anything I can't undo if for some reason I decide to put it back to original.
   / Another approach to power chute rotation for snowblowers #2
Good Afternoon Paul,
Your chain drive looks like the ticket to me ! And it looks like it could take a little abuse.
Real nice job !!!
   / Another approach to power chute rotation for snowblowers #3
Nice job.
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
23222 (A50323)
23222 (A50323)
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
Ford Pickup NR (A50323)
Ford Pickup NR...
