Another Ag tire question
   / Another Ag tire question #1
dourobob
Platinum Member
Just West of Buckhorn, Ontario, Canada
Wheel Horse 522xi
I am considering replacing the current 14.9 24 turf tires that came on my "new-to-me" MF FE 35 with Ag Tires.
From a traction point of view would I be better off with the 11 X 28 Ag tires as specificed in the owners manual or would the 14.9 X 24 size provide more traction because they are a wider profile.
From a cost point of view, assuming new centres, rims, tubes (not sure if the ones on the tractor are in good enough shape to reuse) and tires, is one size more common and/or expensive than the other.
Thanks for any insights.
Bob
   / Another Ag tire question #2
Is the tractor 4wd? If it is, i would stay with the original size unless you want to replace the fronts too. The 14.9s will be a bit taller than the 11s as well as being wider. If its 2wd then I'd go for the larger tires if you are going to be replacing the rims anyway. The original rims may be too narrow to properly mount the wider tires. The larger tires will give you more traction as well as increased flotation and the potential to add more weight with liquid fill than the 11s.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
2019 TIGERCAT 234B TANDEM AXLE DE LIMBER (A54607)
2019 TIGERCAT 234B...
