Another 990 Question
   / Another 990 Question
Om21braz,
I used to own a 2001 4300 sync shift before my 990 and the trans was ok. Not the most direct feeling gearbox like the 990. You can only shift on the go. No rolling and shifting into reverse like a true synconized shuttle. I never got a grind in the 2 years I owned it but the shifter would kind of bind up sometimes and not go into gear. I have noticed on the 4000 and 10 series they have the worst range shift levers. Not very positive feeling and the always bind up. The 990 on the other hand never binds when shifting ranges. I used mine for mowing and had no problems with it. I like using gear transmissions but I have always used syncro my whole life so this collar shift is a little change. I operate a JD 380A gear drive forklift at work and it is really no different than the sync shifts on the 4010 series. They have the same sounding transmission whine and everything. With the forklift it is a sync reverser trans with the lever for F or R on the dash so it is quicker to change direction than the 4010 series sync shift. I would bet you are good at using a clutch and it sounds like you are so a sync shift may be a good fit for you but I would look at the power reverser first for more ground speeds and ease of direction change for the loader work. I use a loader on the 4300 and 990 and find it to be no problem but not as fast as a hydro. 12 F and 12 R compared to 9x3 on the sync shift.
   / Another 990 Question #12
Om21braz - are you looking for a 2WD or MFWD tractor? On the 4000 Tens I think the sync-reverser is the only gear tranny available on the 2WD models and the power-reverser is the only gear tranny on the MFWD versions. Never the twain meet as they say.
Tim
   / Another 990 Question #13
Tim,
Whatever I wind up with will be MFWD. Looking between 4115-4310 Deere or B2410-L3130 Kubota. Trying to decide whether to trade off hydro for HP price-wise. And thanks yellowsocks for your take on the matter. Sorry for interrupting - Ya'll can go back to the JD 990 talk !
   / Another 990 Question #14
And the 4x10 2wd syncs are gone when dealer stock is gone, No new ones being built...
   / Another 990 Question #15
I don't think I've really encountered this, though I do not shift while mowing and I use the foot throttle for everything else... so my RPMs are usually at idle while shifting. Might have something to do with that.
I don't think I have anything to worry about. Most of the time it shifts without grinds. Today I drove a Massey Ferguson 1040 compact gear drive tractor. You gotta put it in S gear to start. It is a collar shift as it did grind when shifting when stopped. Worked good yet for being 20 years old about. Nice little tractor. If I did not have a Deere I would get the Massey compact.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
flooring (A55758)
flooring (A55758)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2006 MACK MR CAB & CHASSIS (A57880)
2006 MACK MR CAB &...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
TANK MANIFOLD (A58214)
