Another 4310 battery question!!
   / Another 4310 battery question!! #1
Deere05
Brazos County,Texas
John Deere 4310
I have seen many posts of problems with batteries on 4310s.
I have a 4310 with 75 hrs. I checked my battery yesterday to see if I anything looked like trouble. I can see a little corrosion (white build-up) on the radiator close to the top rim of the battery. I have not taken the battery out yet to check for other potential problem spots but was bummed about the one small spot I saw. Should I contact the dealer yet or see if it gets worse? The last thing I want is to mess up my cooling system. I plan to take my battery out tonight and investigate further.
   / Another 4310 battery question!! #3
Deere05,
It can't hurt to contact your dealer and let them know your concerns. Has the white build up penetrated the paint on the radiator or is it just on the surface? I would suggest at a minimum that you clean it up and touch up the paint as needed. But first find out what your dealer thinks.
Jeff
   / Another 4310 battery question!! #4
Deere05,
Jeff
I don't know if it penetrated the paint or not. I had to change out a mower belt on the lawn mower instead of dealing with the battery tonight. Time is short when you have to work for a living. Hopefully tomorrow I can check. If I need to paint it would John Deere Black do or is there a specific paint for radiators? /forums/images/graemlins/confused.gif That is probably a stupid question but if I didn't ask then there would surely be something special that I SHOULD HAVE used.
I will call the dealer regardless.
I took the battery off this evening to check the amount of corrosion on the radiator. There is a 5'' X 1'' line that runs along where the top of the battery rests against it. The battery is a Strong Box Hibernator. I tried to remove the white corrosion powder and the part of the radiator fins that are affected break off. I have not called my dealer yet. Any ideas as to what they will likely say and is there a "permanent" fix for this problem if I got a new radiator and battery? I would hate to have it fixed and then it happen again. Especially after it is out of warranty.
   / Another 4310 battery question!! #9
The very best fix is a truly sealed battery like the Optima. Yellow top is the recommended solution, but the 51 is no longer available. There are several other brands, someone posted a battery from Sams..
(BTW Deere offers a battery that looks remarkably like an Optima...)
Could it be that you were inadvertantly overfilling your Deere battery? I think I may have been./ It seems like all my trouble started after I topped mine off...
   / Another 4310 battery question!! #10
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
