Another 1710 question!! Need help!
   / Another 1710 question!! Need help! #1
Nolo263
1986 Ford 1710
My 1986 ford 1710 is popping out of second gear on the range selector. I can feel 1st and 2nd are weak when put into gear and 3rd and 4th have a strong audible click.
I did a search and it is hopefully my detent springs and or detent balls.
Where can I buy these parts before I tear into it!
Update! Fixed my problem, took it apart and found some *** had opened it up at one point and lost spring. They replaced it with what seemed like a pen spring.
Luckily I am a gunsmith and had a crap load of springs that i could trim down to size. Works 100% now! I think I was shy about 1/32 or 1/16 of an inch in length, but still works perfect. Gears go in solid now with audible hard click.
On another note: I found a thread that had pics of how the springs and detent balls are on the 2 shifter on the floor model. The 1710 with shifter on the tree, has a plate below shifter with 3 screws, Remove screws and take plate off and underneath are the 4 springs and balls.
This site is awesome! Learning alot!!
   / Another 1710 question!! Need help! #4
Glad the issue was an easy fix. The 1710 is a solid tractor and should last decades.
2019 Chevrolet Express (A53317)
2019 Chevrolet...
UNUSED PABREAK GB232 - 84" HYD GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
2006 International 4300 S/A Day Cab Truck Tractor (A55852)
2006 International...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
