Another 1710 question!! Need help!
   / Another 1710 question!! Need help! #1
Nolo263
Bronze Member
1986 Ford 1710
My 1986 ford 1710 is popping out of second gear on the range selector. I can feel 1st and 2nd are weak when put into gear and 3rd and 4th have a strong audible click.
I did a search and it is hopefully my detent springs and or detent balls.
Where can I buy these parts before I tear into it!
Update! Fixed my problem, took it apart and found some *** had opened it up at one point and lost spring. They replaced it with what seemed like a pen spring.
Luckily I am a gunsmith and had a crap load of springs that i could trim down to size. Works 100% now! I think I was shy about 1/32 or 1/16 of an inch in length, but still works perfect. Gears go in solid now with audible hard click.
On another note: I found a thread that had pics of how the springs and detent balls are on the 2 shifter on the floor model. The 1710 with shifter on the tree, has a plate below shifter with 3 screws, Remove screws and take plate off and underneath are the 4 springs and balls.
This site is awesome! Learning alot!!
   / Another 1710 question!! Need help! #4
Glad the issue was an easy fix. The 1710 is a solid tractor and should last decades.
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
40' High Cube Multi Door Container (A50121)
40' High Cube...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
Guard Rail Joints (A51692)
Guard Rail Joints...
