angle
   / angle #2
I use 30-45° angle always turning the dirt to the side I want to build up, usually the middle of the road if working on roads. The sharp angle helps eliminate the dips.
   / angle #6
angle setup for back blade
Are you asking how to setup a hydraulic cylinder to adjust the angle?? If you are asking just what angle to manually set it, it's depends on how much snow (or dirt) and how wet it is... You may have to set it a could of times and play with it.
What worked for in the straight-a-ways... would be too much for drifts (and swing the back of the tractor around).
It's your first post, don't worry about it. Just add more information.
   / angle #7
Since you are posting in the Hydraulics form, I'm guessing that you are looking for a hydraulic angle kit for your rear blade for your BX2200? If this is correct, a picture or pictures of your rear blade would really help. On this size rear blade, there are no factory hydraulic blade functions that I am aware of. Pictures will make it possible for us to make meaningful suggestions to make this addition possible. ;)
   / angle #9
Lacking a whole lot of details. I didnt even see a question asked?
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
