angle
/ angle #2
I use 30-45° angle always turning the dirt to the side I want to build up, usually the middle of the road if working on roads. The sharp angle helps eliminate the dips.
/ angle #6
angle setup for back blade
Are you asking how to setup a hydraulic cylinder to adjust the angle?? If you are asking just what angle to manually set it, it's depends on how much snow (or dirt) and how wet it is... You may have to set it a could of times and play with it.
What worked for in the straight-a-ways... would be too much for drifts (and swing the back of the tractor around).
It's your first post, don't worry about it. Just add more information.
/ angle #7
Since you are posting in the Hydraulics form, I'm guessing that you are looking for a hydraulic angle kit for your rear blade for your BX2200? If this is correct, a picture or pictures of your rear blade would really help. On this size rear blade, there are no factory hydraulic blade functions that I am aware of. Pictures will make it possible for us to make meaningful suggestions to make this addition possible. ;)
/ angle #9
Lacking a whole lot of details. I didnt even see a question asked?
JOHN DEERE Z960M ZERO TURN LAWN MOWER (A62130)
JOHN DEERE Z960M...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
PALLET OF 12 IRON GATES (A60736)
PALLET OF 12 IRON...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2012 Ram 2500 4X4 Pick-Up Truck (A61568)
2012 Ram 2500 4X4...
Pat's QH and hydraulic top-link.
Pat's QH and...
