Angle iron on FEL Bucket
   / Angle iron on FEL Bucket #1
jhortonvt
Northwestern VT, On Lake Champlain
John Deere 4310
After much consideration of opinions on TBN, I decided to put angle iron on the top of my bucket vs hooks alone.
A few of the notables I thought were valuble:
-The angle iron kills two birds with one stone by providing attachments AND stiffening the bucket's top plate
-The slots act as grab hooks for chain but I plan on setting up a slip hook with a couple links of chain to set in the slots
-The angle iron helps keep material in the bucket when full to the brim /forums/images/graemlins/smile.gif
Here are some pics....
So the first one was the 3/8 angle iron cut to fit the bucket.
This one shows my marking to bevel for the existing weld.
Well I've got more pics but the files are too big. Not sure why they're different size than the other pics but I'll have to work on that tomorrow.
More to follow...
   / Angle iron on FEL Bucket #6
Looks good. When are you gona make the bucket shinny? /forums/images/graemlins/grin.gif
Egon
   / Angle iron on FEL Bucket #7
Good idea. However when you cut all those slots you lost a lot of your stiffening value. Hollow square tube w/ a 3/16 wall would have served you better. But then you wuold have had to but a few hooks.
   / Angle iron on FEL Bucket #8
Good idea /forums/images/graemlins/cool.gifare you also considering maybe adding on iron under top of the bucket to make it tad stronger??
   / Angle iron on FEL Bucket #9
Just curious about your bucket since you didn't have a "before" picture. Deere makes several different buckets.
I'm guessing that the top of the bucket simply had an open curl of sheet metal as top lip? What are you going to do to reinforce the angle iron slots? Are you going to weld small triangles in on the backside, on either side of the slots so they simply don't bend/flex open under load?
I like the idea of multiple slots cut so you can adjust load connection points. Neat idea.
   / Angle iron on FEL Bucket #10
It looks good, but I too wonder about those notches taking away strength, also a chain hooked in one of those could easily bend the angle, there is a lot of force there.
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Noble 8 Row Cultivator (A50514)
Noble 8 Row...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
