And There Done, Guage wheels
   / And There Done, Guage wheels #1
jjcc246
Buffalo, New York
2004 TC30
I did a progress report (pictures) in customization section. But this are the final pictures. Now when the mud dries up and I can get to the rake I can install them. I extended them 18" from the tine bolts and the length of the leg is 24" plus the 8" wheel that should give me plenty of adjustment. The wheels I used are from HarborFreight (item #46818 swivel caster). They are hard rubber and a zerk fitting on the axel. Got them for $11.99 with coupon. Total spent I would say around $40.00. I think they should work pretty good. Thanks for looking.
   / And There Done, Guage wheels #3
Nice work JJ! :thumbsup:
Let me know how those hard tires do.
   / And There Done, Guage wheels #4
Depending on how rugged your terrain is, ups, downs, bumps, etc. how do you think hollow box stock tubing vs. solid bar stock for the arms will work out? Looking forward to the working photos. Good job!
   / And There Done, Guage wheels #5
Have you given any thought to coming up with a way of keeping dust out of the ball-beaings that allow the caster to swivel. If not, you may give some thought to using some silicone caulk on the joint (but obviously keep it from getting into the bearings) as sort of a bearing seal. To make sure it doesn't tear, wipe one surface with a little grease or oil first (extremely lightly, so only a film remains) and then create a covering of the joint with the caulk. I'm afraid unless you've done something, that bearing area will quickly be shot.
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
TANK MANIFOLD (A58214)
2012 Jeep Grand Cherokee SUV (A56859)
2012 Jeep Grand...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
