fishpick
Platinum Member
As I was bush hogging the field... and getting about ready to be done for the night as light was quickly fading...
The tractor started loosing power - lurching - I thought "what has been maybe sucked under the hog?" So I killed the rear PTO... still the tractor languished - sounding less and less likely to keep running... so I upped the throttle - thinking - "she sounds like she's out of gas... but no way, because I just dumped 5 gallons in and the gauge reads full"
Soon - it was me - in the setting sun... on a silent tractor...
Expletives aside - I noted the following symptoms:
No sound of the fuel pump when the key was on... but the glow plug lights still registered
No head lights or turn signals... but the hazards worked
No life on the display - and no other idiot lights...
Had to be a fuse - so I pulled out the manual from under the seat... sure enough - it's a blown fuse labeled ACC 15A... replaced it with the spare 15A and she started right up - no issue...
So the question is - what the h-three-double hockey sticks blew that fuse...
