Eyecatcher
- Joined
- Apr 12, 2012
- Messages
- 362
- Location
- Pomona Park Florida
- Tractor
- Yanmar EX450, Ford 8N/2N, Case 580C backhoe, Massey 185
Finally got the old 8n on the road to re-assembly. About half of the radiator shroud was missing, but the rad didn't leak, and the tractor didn't run hot, what little I had ran it, so found a used shroud, gave it and the rad a new black paint job, and re-installed. Fan hit the bottom of the shroud. New mounting pads, shroud like new, what the heck? Soon found that the mounting bracket solder joint had failed next to the lower hose. Rad has a metal tag soldered to the fins, which I assume indicates a new core had been installed at some point in time, but the rest of the rad is a little rough, dents, globs of solder etc. We have a local rad shop that does good work, & I figured it would be better to take it to him than try to fix myself. He agreed with me that it would be better to just re-attach the bracket rather than try to rod it out etc., as old as it is. Said he had to remove the bracket, sandblast the tank, reattach and leak test. Said if he didn't find a lot of leaks, it would run $40 - $50. Called me & told me that the brass lower tank was old, and the metal was pretty brittle. He had remounted the bracket twice, and it didn't leak with the bracket off, but as soon as it was re-attached, small cracks would show up in the tank. Said he thought he finally had it, but advised me that it would probably be ok, with no pressure on it, fill it, run it, and don't replace any water that came out the overflow. Said he would even remove the rubber seal from the rad cap. Guess I'll try it, but think I'd better start looking for a rad. Bottom line is, I invested $50 in a bum radiator. By the time I get this thing back together, it will be the most expensive N in Fla.
