and another trailer build
   / and another trailer build #1
tatra805
Okres Pezinok
Iseki TL1900FD
next: Building a trailer
I intend to build a trailer in the coming days which should go with the TL, and only with the TL.
A commercial grade trailer does not stand the time (manure is agressive) and is constructed to be light and cheap, that was not an option. Agricultural trailers for small tractors are or too small or way out of budget.
My requirements:
- build to last, payload of 2 ton (volume more important than weight but construction wise able to be loaded without worries about flexing metal)
- not wider than the tractor
- can be loaded without the tractor attached
- prepared for installing a tipping cylinder (dont have aux hydraulics yet so thats for later but influences the design)
I do have a 2ton military trailer frame which i will use as base. This trailer has leaf springs which i will remove. I intend to use the axle and have the hubs converted to take 5 bolt landrover wheels. Wheel size will be 235/85R16, around 80cm high wheels what brings the frame and so the hitch a couple of cm higher than 40cm, and exactly in line with the original towpoint on the TL.
Here it is:
As you can see the wheels have brakes, i dont want to install a run-up brake mechanism but will install a handbrake mechanism.
The support feet will be relocated to help stability when loading (might skip them and just make something more sturdy)
The loadbed wil have to be ---_____---- shaped (whole length for the dumping feature) to accomodate the wheels (TL is not wide) i dont want to make a platorm as this would higher the whole trailer and make it unstable. (i was thinking about a double axle flatbed but that would limit me in maneuvering around the place too much.
Bottom part between the wheels will be around 0.9 meter and the top wings widen it to 125-130cm, lenght 2meter and complete lenght of the trailer 2.8 meter. (my gangway in the stable is 3 meter wide so i should be able to turn the empty trailer by hand)
Grid sides (removable) to load the manure, split wood etc and a when removed a base for transporting bales of straw (2 meter long so only 30cm overhang)
More to follow as progress goes, all input welcome this is my first trailerbuilding attempt.
Started tonight.
Base frame and 'the hinge' are finished.
Decided on position of axle etc
Ready for tomorrow.
Now, just some ranting
Bought a new bunch of electrodes, shop did not have my usual brand and i am :mad::mad::mad: these things just dont weld as it should be. 6013 is 6013 or not? Yes the other ones had a red end and were base type but typenumber id was 6013. (both are from "big" brands)
Well these new ones made me go over almost each weld. Even checked the mains voltage to see if that was the cause or something but no, same batch of metal as the implements i was making earlier last week, same place, same welder, same weather.....
   / and another trailer build #3
Any chance the new 6013 are damp from moisture? Did they come in a sealed container?
   / and another trailer build #4
If you suspect the rods have drawn moisture you can "bake them" to dry them out. I have done so in the past. I keep my rods in airtight containers like this
rods are ESAB 6013 came in sealed pack of 250 pcs.
I bought one pack 3,xx mm about 3 months ago, never used them and a couple of days ago a pack of 2.5mm. i opened both at the same moment when the other brand pack was finished.
It are the rods, i tell you quality is different and my limited welding experience (all trial and error never any schooling) does not compensate.
I should search back the old pack in the wastebin and find out what the difference is. I bought them in belgium so they were opened minimum 4.5 years, just stored in the shed, winter and summer, no care taken en no problems.
Really bothers me :(
   / and another trailer build #6
Tatra Ive had the same experience with ESAB and Lincoln rods to. i usually weld with a Hobart rod or a Mackay rods. Mostly what I use is 7018. To me the ESAB is very goopy. Good looking trailer there, I need a small dump trailer for around the yard where I cant get my dup truck to I have a bed already framed up from the cab of a warehouse lift.
   / and another trailer build #7
Tatra805, where do you live ? You said you bought electrodes in Belgium, and a Tatra 805 is the Czech equivalent of the MB Unimog... :)
Didnt look for the box of the old ones yet, in any case the esab things only weld horizontal and even that is a hassle. I'll reserve them for scrap welding for some gate posts which will be put in concrete afterwards and look for some good rods asap.
Renze,
I am original from the region of Gent. I had my tatra805 in belgium and bought it in Slovakia. (that time i was about half time in slovakia for my job) After the whole reconstruction of the tatra which took 2 years of daily a couple of hours i moved to.... slovakia and took the tatra with me again. (live here now permanently for 4 years) Funny detail about that was that i had to get permission for export from the ministry of culture in slovakia but when i wanted to re-import the tatra i got the message from the ministry of transport that the car was too old to be put back on the road in slovakia ????!!!!:confused::confused:
You are right about the unimog-tatra relation in that way that the unimog is a (poor mechanical) copy just as the volkswagen beetle is based on the plans (stolen from tatra by some engineers for porsche) of the T-57 (if i recall the number correctly).
Now, about the trailer, some more pictures:
Left the axe free (only bolted down) so i can still move it once everything is finished and i actually can feel and see the real balancepoints.
Looking at height and proportions all limited by the 125cm width of the TL i had to change plans a bit an skip the -----________----- loadbed idea. I will have a smaller load capacity this way but the thing would be completely out of proportion (and entering the +300kg empty range). So a usefull cargo volume of 80x200x40 without side extensions and 80x200x80 with the side extensions. Gives 0.64 and 1.28 cubic meters. or if loaded with manure a load of 0.6 or 1.2 ton. just within target range.
I figured in the mean time i will need a 40cm (80 extended) hydraulic cylinder to lift. Wheelhubs are in the make when Zoro finds a spare moment so maybe in a couple of days i can actually move the trailer on its wheels. Christmas is putting a brake on things, small village so no grinders or chainsaws to be used in these days. Maybe i if i use enough cutting fluid i can drill something and a welder will look as some celebration fireworks...:p
In any case a Merry Christmas to you all!
   / and another trailer build #9
Yes thats right: Hans Ledwinka was the engineer who held about 20 patents, used in the T-570 prototype. He discussed these with his engineering friend, Ferdinand Porsche. ****** put pressure on Porsche to develope a "peoples car" as a propaganda stunt. In this short timespan, Porsche broke 20 of the patents applied to the Tatra T570 prototype. In 1961, VW payd 3 million reichsmark to Tatra for breaking those patents. They got away with a steal, paying 8 Reichsmark and 33 cents for every one of the 25 million Beetles ever made....
You're right the T-805 is a better offroad chassis with its independent suspension, though it never became such a cult car as the Unimog in Western Europe, and even America.
Anti-east propaganda still holds up around here, even though its allmost 20 years since the iron curtain fell...
next small steps
While the floor plate (2mm metal) is in place I am now little stuck with shortage of materials to continue the side plates.
So i played a bit with the brakes and made an own mechanism to apply the brakes. Old style turning to apply the brake but that should also work i asume.
Then i cut of the front support and mounted a jocky-wheel i had laying around. The wheel is mounted in such position that when locked and folded up the small wheel is horizontal and not sticking out / hanging lower than the axle. Saw to many of them torn off in ditches not to care.
Vertical
Horizontal
Oh, and today i went for some firewood. Does not look as much but once back on the road i noticed that the tyres of the trailer were looking heavily under inflated. After unloading i drove near the compressor and ....i had 2.5 bar in them :eek:. Suppose that this walnut wood is quite dense.
Iseki was behaving great on his first real outing. (fyi, the white house on the right side of the picture is at the other bank of the valley, the wood i am getting comes from the stream down this valley, so had my first serious up and downhill experience) Happy owner, tomorrow i go back for 2 loads and in the afternoon i have to move some ground with the neighbour.
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
Rollback (A53117)
Rollback (A53117)
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
