An unpleasant problem not covered under the waranty
   / An unpleasant problem not covered under the waranty #41
So from what you are telling us....there is a mouse pancake in the seat....um...yea...not good...not good at all. I think I would just buy a replacement Kioti seat cushion at this point for your model seat or take it to get reupholstered.
I'm curious why a John Deere cushion would fit?
It's his machine but we agreed there were several things to try before giving up.
I wanted to find those beetles that clean off old skulls, but the ants are worth a try.
   / An unpleasant problem not covered under the waranty #43
This has become ridiculous. Recognize this fact - if there are dead mice in that seat cushion - they will begin to stink and unless the seat is taken apart and cleaned - they will stink and attract other mice for a whole lot longer than most people would be able to tolerate. You can play the silly games with the ants and beetles but a stinking, rotten mouse will stink for a loooong time.
And if you should be so unlucky - multiple stinking, rotten mice will stink a whole lot longer.
Just heard from him, and this weekend the stink is gone....
   / An unpleasant problem not covered under the waranty #46
Sorry, you left off the NX so when you said it was a friend's 5510 that leads some of us to think a JD 5510 since that is the only tractor I know that is listed as just a 5510. My bad...
   / An unpleasant problem not covered under the waranty #47
Beans!
Eat beans for a week. The mouse smell will be displaced.
   / An unpleasant problem not covered under the waranty #48
I'd hardly call the use of insects (and other arthropods) etc. as "ridiculous"...considering the FACT that they are used by professionals in several fields...including taxidermy and museum specialists...many museums keep colonies of Dermestid beetles and also ants for defleshing and removing all soft matter from animal specimens...
Also, I've never heard of a decomposing mouse attracting other mice...flies maybe but not mice etc...
   / An unpleasant problem not covered under the waranty #49
Couple of points - - I have no idea where you will get SIAFU ants(driver ants). May have to ship the seat to South Africa where the ants are - exotic species, importation not allowed except under special conditions - - Ex- museum.
You could well be correct - dead mouse may not normally attract other mice - sure does around my place here. However - dead ANYTHING will certainly attract rats.
BTW - just uphill here a bit the word is - the stink is gone. Good news - no ants nor beetles required.
   / An unpleasant problem not covered under the waranty #50
No one said driver ants. Good old US ants and beetles can be found in your backyard. I don't use ants but I have a good population of native beetles that will clean skulls just a few feet in my woods. They are not the exotic variety that museums and professional taxidermists use, but they get the job done. I was thinking about setting up a colony in my barn, but I don't want to deal with them in the winter. They require constant feeding. The beetles do not eat flesh, its the larva that do. They don't fly until its over a certain temp 80 something, I cant remember the exact temp, so you can keep them in plastic containers. You need to skin the "parts" before you let the beetles get at them. They do not eat skin. You should also put a screen on top of the container, if you keep them inside. You do not want flies getting in because it will stink.
One of the worst killers of native songbirds is invasive bird species. The European house sparrow kills blue birds at an alarming rate. I have found more headless blue birds on my property than I can count. I have researched it, and found that the invasive sparrow from Europe will destroy entire populations of native songbirds. The sparrow pecks the heads of the native blue bird, that instinctively protects its young by shieling them with its wings, until its dead, then the sparrow makes a nest on top of the dead blue bird family. Both the male and female invasive European house sparrow will kill the native birds. This happens in bird boxes across the country. It happens at such an alarming rate that it was recommended to reduce the opening size of your birdbox so the bigger invasive species won't kill the native species for the nest.
The Starling is equally guilty of killing native birds. They are much more easily identified as they are the only black bird with a yellow beak in North America. Juveniles are greyish brown with black beaks. Unfortunately the house sparrow looks like several native bird species, so identification if difficult at a distance.
I am not a birder or granola cruncher, I was just trying to figure out what was killing the native birds around my house. My declawed indoor cat doesn't eat the heads off of birds, nor does my Rottweiler care about birds. The Rott will unstack a cord of wood in ten minutes to get at a mouse nest though.
The main point of this post. If your cat isn't killing invasive European bird species, you should be doing that. Native bird species will love you for that.
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
Ford BL223C Utility Tractor (A55851)
Ford BL223C...
Hose Reel (A53424)
Hose Reel (A53424)
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
