An electrician's nightmare.
   / An electrician's nightmare. #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I built my present barn 20 years ago and have never had an electrical problem except when lightning hit the cable for my surveillance camera that runs from my barn over 1000' to my house and burned up the camera.
I went to my barn Sunday and saw a line of ants running up to and into my panel of light switches in the barn. I have 5 light switches on 3 different circuit breakers in the hallway and an additional switch on the other side of the wall in the tack room. I went to turn on the lights to see the ants better and none of the lights on the 5 hall switches worked but the light in the tack room worked. I was thinking that possibly the ants had something to do with it since the lights worked yesterday.
I removed the cover plates of the switches and the cover of the circuit breaker box looking for clues expecting to see some damaged wiring. All wiring looked good so I checked the breakers and they were all good then I checked the switches and all 5 switches in the hall were bad. After replacing the switches all lights worked fine and no light bulbs were damaged. Some lights are LEDs, some fluorescent, and some CDL lights. All 6 switches in the barn only have 2 wires going to them, the hot wire and the wire to the light, no ground wires.
My next door neighbor is a retired electrician who has traveled the world doing electrical work in industrial plants so I asked him what could have caused these switches to burn out. He didn't believe me and got his meter and checked them and saw that they were indeed bad. He said he never heard of such a thing before and acted slightly embarrassed since he could not answer the question with all his years of experience.
Does anyone have a clue as to what could have caused this?
   / An electrician's nightmare. #2
Open the switches. (likely have to drill out small rivets) and take a look at the contacts.
   / An electrician's nightmare. #3
Another lightning strike?
   / An electrician's nightmare. #4
My mom's gate openers stopped working, turns out there were ants in the control box, once cleaned out they worked again...
   / An electrician's nightmare. #5
Switches rely on metal to metal contact.
On knife switches the 'male' blade slips between the 'female' blade and so can self clean.
On typical toggle switches the contacts simply touch each other under spring tension.
Fry a bunch of ants between those contact points and ergo, insulated and no contact.
Then again as heat and age gets involved any lubricant (and there is always some) hardens and so hence bad connection.
Older wall switches made a loud snap or clack when activated.
Newer designs are more silent but then use much weaker springs so it takes very little to inhibit good conductivity.
   / An electrician's nightmare. #6
That's odd. I've never been an electrician or traveled the world. I've worked in a few plants and passed by many others. I've stayed in few Holiday Inns, not sure about an Express. But I've seen lots of switches go bad for all sorts or reasons. Corroded or arced contacts, broken springs, broken housings, debris intrusion .....
   / An electrician's nightmare. #7
Yes but he had 5 switches fail all at once..
   / An electrician's nightmare. #9
Why do ants always end up in electrical boxes?
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2019 Ford Fiesta (A55853)
2019 Ford Fiesta...
UNUSED FUTURE BK56 BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BK56...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
JOHN DEERE 5425 TRACTOR (A54756)
JOHN DEERE 5425...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
